20 Most Recent Zanussi ZHQ575 Electric Double Oven Questions & Answers
to remove the glass door open the door and you will see two round locks each side of the door with slots just turn the slots with a screw driver and life up the door and pull when putting back push the door back in the 2 slots let it rest in and just pull a little to make sure it in and release the two round locks
Zanussi ZHQ575... | Answered on Jan 16, 2018
You could but if you disable the timer and anything goes wrong with it could invalid your house insurance if anything went very wrong.
Zanussi ZHQ575... | Answered on Jan 09, 2018
Solid line at top indicates the grill. Two indicate the oven.
Zanussi ZHQ575... | Answered on Sep 22, 2017
Susan, in what country did you buy the oven? The codes differ per country.
Does the model tag look like this?
Of course it might be difficult to FIND the tag...
Let me check where they stick those....not-find-manual-model-number-ze0505x-cluqxvqmjdhmibjs3bae0uvv-4-2.png
See above location in red.
You can lookup manuals on zanussi.com by using the PRODUCT CODE as well (the serial number does not help). Check if the product code gives you a result on this page:
http://www.zanussi.co.uk/Support/Manuals/
Zanussi ZHQ575... | Answered on May 18, 2015
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
god is gooddddd
Zanussi ZHQ575... | Answered on Apr 29, 2015
I would say you are right on your wondering. look at your manuel and it will show you a diagram
Zanussi ZHQ575... | Answered on Mar 30, 2015
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Zanussi ZHQ575... | Answered on May 28, 2014
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Zanussi ZHQ575... | Answered on Mar 07, 2014
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Zanussi ZHQ575... | Answered on Mar 05, 2014
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Zanussi ZHQ575... | Answered on Sep 21, 2013
Sounds to me as though the external cooling fan is not working.
As it is brand new, I would advise you to contact the people that sold it to you, you have the right to insist on having it replaced if it is faulty, and under 28 days old.
Zanussi ZHQ575... | Answered on Jun 24, 2012
They may be rivet holes. On my Zanusi the thin panel that goes across the top of the glass to hold it in just slides off forwards toward the cooker.
Then the glass slides out upwards.
Zanussi ZHQ575... | Answered on Apr 16, 2012
Zanussi ZHQ575 Electric Double Oven Logo
75 questions posted
Top Zanussi Ovens Experts
John Tripp
John Tripp
Jason Harris
Jason Harris
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Ovens
  • Zanussi Ovens
Most Popular Question
grill not working after replacement
  • Ovens
