MIX 1/2 VINEGAR &1/2 WATER PUT INTO SPRAY BOTTLE TO CLEAN. IF CLEANING INSIDE BOTH PANES OF GLASS YOU WILL NEED TO TAKE OFF THE INSIDE PANNEL TO CLEAN. USUALY THERE ARE ABOUT 4 TINY SCREWS THAT HOLD IT ON.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
circular element round the fan has blown. take back panel off inside oven and you will see element. to replace, take rear outside panel off and usually element is held in by 2 7mm nuts on posts sticking out of the element base plate. easy job. disconnect of course
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element. Here are the 3 main faults to look for in your oven or cooker that is not heating
If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
According to the Manual, section about Electrical Connection Pg14 is that there is no fuse as it is connected to the buildings main fuse box via a double pole switch between oven and the mains electricity.UserGuide\ManualOven Diagrams
Hi intial problem will probably be a faulty heating element locatated behind the panel at the back. the zbf260 has no clock but if its a zbf 360 set the clock before the oven will function. otherwise the fault has damaged another component on the oven. which can be in order of most likley.fuse if on 13a supply/ thermostat/ selectorswitch/ thermal cutout/jw
I've got the same issue, looking at them it's either the blue or yellow ones you want, the manual states that it should be installed with 2.5mm flex cable if going to a plug and 2.5mm twin and earth cable if your going to an electrical outlet.
All ovens are made of steel with a enamel lining generally speaking.
Ypu can use virtually any product for cleaning as long as it says for cleanin ovens and the like, just follow the instructions on the product.
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
