20 Most Recent Zanussi ZBS963X Electric Single Oven Questions & Answers
0answers
0answers
Oven won't turn on, had a power outage on the
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
7/23/2012 8:09:05 PM • Zanussi ZBS963X... • Answered on Jul 23, 2012
Cannot get light out
It may sound silly, but it works. lay down the oven and spray the part where it screw in with Coke leave for a few minites and spray again, try turn it out now, that work believe me
12/12/2010 6:30:27 AM • Zanussi ZBS963X... • Answered on Dec 12, 2010
My zanussi ZBS773 wont switch on, the clock is
If numbers are flashing press button "-" or "+" .When the correct time is displayed confirm the setting by pressing the square button with a "c" on. The clock will start runnning.
If the numbers are static press buttons l-> and l-> in at the same time and hold both of them in until the numbers start flashing . Release buttons l-> and ->l
then adjust the time by pressing "-" or "+" and confirm by pressing the square button with a "c" on .
4/11/2010 5:34:41 PM • Zanussi ZBS963X... • Answered on Apr 11, 2010
I don't know what wattage I need for the bulb
You can fit a 15 or 25 watt bulb, as long it it is the correct thread, and it is able to withstand 300 degree temperature.
This is very important, otherwise it will blow with the heat.
Hope this helps.
1/20/2010 9:04:20 AM • Zanussi ZBS963X... • Answered on Jan 20, 2010
2answers
The bulb seems to have fused. How to remove the
No, you should be able to replace it within the oven space. The cover should unscrew and reveal the bulb which you then remove and replace.
1/19/2010 1:56:56 PM • Zanussi ZBS963X... • Answered on Jan 19, 2010
Simpson Evolution 906 Fan forced oven
have you solved it?
John
8/29/2009 4:05:19 AM • Zanussi ZBS963X... • Answered on Aug 29, 2009
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
6/22/2008 10:57:07 AM • Zanussi ZBS963X... • Answered on Jun 22, 2008
2answers
Zbs 1063 - POBERR 80
Take note of the error code(POBERR 80) and contact an authorised
Service Centre.
11/25/2007 9:48:28 PM • Zanussi ZBS963X... • Answered on Nov 25, 2007
ZBS 1063 displayng
You have activated in some way the "child protection" function.
Please, check on the instruction book how to deactivate it .
11/24/2007 5:12:47 PM • Zanussi ZBS963X... • Answered on Nov 24, 2007
Door
there are various ways of doing it but essentially you have to lock the hinges before removing door. sometimes a little arm which flips up or a circular slotted plate on the door
3/20/2007 4:45:59 PM • Zanussi ZBS963X... • Answered on Mar 20, 2007
Clock
Here is a link to the owner's manual: http://www.serviceforce.co.uk/pdfs/U22392.pdf
2/21/2007 10:15:44 PM • Zanussi ZBS963X... • Answered on Feb 21, 2007
Error code 367Zanussi cooker not working what is the cause of the error code 367
Error code 367 on a Zanussi cooker typically indicates an issue with the temperature sensor or thermostat. When this error occurs, it means that the temperature sensor is detecting an abnormal or out-of-range temperature. Here are some possible causes and steps you can take to troubleshoot the issue:
  1. Power cycle the cooker: Turn off the cooker and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes, a simple power cycle can resolve temporary glitches or errors.
  2. Check the temperature sensor: The temperature sensor is responsible for detecting the oven's temperature and sending signals to the control board. It's possible that the sensor has become faulty or disconnected. Inspect the sensor for any visible damage or loose connections. If necessary, consult the cooker's user manual for instructions on how to access and check the sensor.
  3. Inspect the thermostat: The thermostat regulates the oven's temperature. If the thermostat is malfunctioning, it could be causing the error code 367. Look for any signs of damage or wear on the thermostat. If you suspect a faulty thermostat, it may require professional repair or replacement.
  4. Contact customer support: If the above steps do not resolve the issue, it's recommended to contact Zanussi's customer support or a qualified technician for further assistance. They will have the expertise to diagnose the specific problem with your cooker and provide guidance on the necessary repairs or part replacements.
It's important to consult the cooker's user manual or documentation for model-specific troubleshooting steps or error code interpretations. The manual may provide additional information or suggestions for resolving error code 367 on your particular Zanussi cooker.
5/18/2023 2:45:40 PM • Zanussi Ovens • Answered on May 18, 2023
Hi the grill on my zanussi freestanding cooker is not working but the oven and hob are still working and we replaced the element in the grill so it's not that
If you have replaced the grill element and it still doesn't work, there are a few other things you can check. First, make sure that the grill is actually turned on and that the grill control knob is set to the correct temperature. Next, check the grill's thermostat, which is typically located near the grill element. Use a multimeter to check the continuity of the thermostat, as a faulty thermostat can prevent the grill from heating up. If the thermostat is functioning properly, you may need to check the grill's selector switch, which determines whether the grill or oven is used. A faulty switch can prevent the grill from working. Finally, if none of these solutions work, there may be a wiring issue within the grill or in the main control board of the cooker. In this case, it may be best to seek the assistance of a professional technician to diagnose and repair the issue.
2/26/2023 1:11:02 PM • Zanussi Ovens • Answered on Feb 26, 2023
How do I remove my Zanussi ZNM11X built in mircowave oven
  1. Turn off the power to the microwave oven at the circuit breaker or fuse box.
  2. Remove any food or dishes from the microwave oven.
  3. Carefully open the microwave door and remove the screws or clips that secure the microwave to the mounting bracket.
  4. Disconnect the electrical wires from the back of the microwave oven. Be sure to turn off the power before doing this.
  5. Carefully lift the microwave oven out of the wall or cabinet. It may be heavy, so it is a good idea to have a helper to assist you.
  6. Once the microwave oven is removed, you can either dispose of it or store it in a safe place until it is ready to be reinstalled.
1/3/2023 11:24:59 PM • Zanussi Ovens • Answered on Jan 03, 2023
Zanussi ZBS963X Electric Single Oven Logo
33 questions posted
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Ovens
  • Zanussi Ovens
Most Popular Question
oven turn power outage
  • Ovens
