Emma, your dehumidifier doesn't have a heater. I think you are confusing the Thermometer button as a heater. The Thermometer button is for setting the the ambient air temperature in the room, the unit is running in. It doesn't change the temperatue in the room one way or another. It's not necessary to set it, unless you're operating the dehumidifier in a basement. That's the only time it would affect the unit's performance.
I hope this helped you.
I appreciate your inquiry, friend!
I see that you are having a complication with your Frigidaire dehumidifier going back to 30% after setting it. This could be a possible issue with your sensor or control panel. I would recommend performing a reset and you can do that by unplugging the power cord for roughly ten minutes. Are you currently in warranty? I would suggest contacting your manufacturer to see if there is any additional coverage on your dehumidifier. Best of luck! -Matt
Thank you for your inquiry, friend!
From what you have described you would like to use your Frigidaire dehumidifier for a heater. Unfortunately you are unable to use your dehumidifier as a heater. You dehumidifier will pull air from the room and distribute the same air. I would not recommend performing any alterations on your dehumidifier as that can void any warranty. Hopefully this is helpful. -Matt
Hello friend, I appreciate your post!
From my understanding your Frigidaire dehumidifier is shutting off and on without removing any moisture from the air. I would recommend trying a different outlet within your basement and adjusting the setting to see if that would help. Additionally, try to turn the unit on continuous drain to see if it pulls any moisture out of the air. If your appliance continues to shut on and off I would reach out to the manufacturer to see if they could assist with any additional resolution. Hope this information proves helpful. -Matt
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status:
In Stock
Price:
$107.79 -
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
