follow this steps and fix it. God bless you
Unless
you are licensed and qualified professional, do not try to repair a
dehumidifier by yourself. If your unit is running constantly yet there is no
water in the tank, try lowering the temperature control. If the problem
persists, there may be a problem within the refrigeration system. You may need
to pull the filter and clean it. Also try wiping off the unit itself. When the
water tank is full, the unit will shut off and will not run until the tank is
emptied. The dehumidifier shuts off by a safety switch in the back of the unit.
If the switch is not working properly, you may try manually pressing the button
or slightly bending the switch.
Motor
If the fan motor is damaged or will not work, no
cool air will be coming out of the dehumidifier. The unit, however, may still
run. You may need to replace the motor. If the coils in the back of the
dehumidifier constantly freeze, try turning off the unit for an hour or
re-locating the unit to a higher position to allow the room to heat up. If your
water tank is constantly full and you are emptying it on a daily basis, you may
have a water leak somewhere in the room with the dehumidifier.
