20 Most Recent DeLonghi DN 125 Dehumidifier Questions & Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
DeLonghi DN 125... | Answered on Jul 13, 2011
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
DeLonghi DN 125... | Answered on Jun 01, 2011
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
DeLonghi... | Answered on Nov 04, 2019
all this info is in the manual. Either you threw it away or are a person who does not like to read.
DeLonghi... | Answered on Oct 28, 2019
David Mury Oct 20, 2019
On the back there are two top screws, two middle screws, and one bottom screw. Make sure the hose attachment is off. On the front there are two bottom screws. Each side has one screw at the bottom (longer than the rest). Remove all that I have mentioned. You will need to wiggle the two halves apart but they will come. Once the back has been removed, there are two more screws on the inside that need to come out before you can get the front sleeve off. Good luck.
DeLonghi... | Answered on Oct 20, 2019
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
DeLonghi... | Answered on May 16, 2019
Usually happens when the float valve is stuck in the down or up position try wiggling the handle to release or if the collection bucket is not sitting perfectly on the safety switch has to be down square I have the delonghi dem10 model always empty and unplug before checking
DeLonghi... | Answered on Jan 31, 2019
Dear Heemin,
From the wording which you have used, it appears you think you are talking to the DeLonghi company.
You are not.
You are speaking to "fixya:".
Please contact DeLonghi or one of it's dealers by finding their access information on your computer's search engine.
God bless your efforts.
DeLonghi... | Answered on Jul 05, 2018
Try Googling (DeLonghi)(DDe 50e)(manual) without parens.
DeLonghi... | Answered on Apr 19, 2018
Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
DeLonghi... | Answered on Nov 20, 2017
It's basically an air conditioner so if the fan is running---the condenser not plugged up via rats nest---lint----the float switch working---if possible tip over switch working----the system maybe low on refrigerant
DeLonghi... | Answered on May 31, 2017
DeLonghi DN 125 Dehumidifier Logo
Popular Tags
5 questions posted
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Dehumidifiers
Most Popular Question
dehumidifier no longer
  • Dehumidifiers
