Refrigerators Logo
Posted on Aug 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model - 561
Fridge stpped working
Anonymous
Level 3:
  • Master 813 Answers
  • Posted on Aug 24, 2008
Anonymous
Master
Level 3:
Answers
813
Questions
6
Helped
352747
Points
2058
Chak the compreasor or power supply
Anonymous
Level 3:
Master:
  • Master 382 Answers
Anonymous
Master
Level 3:
Master:
Answers
382
Questions
0
Helped
93278
Points
1022
Does the compressor works or you mean the fridge is completely dead..Please reply back with more details..Thank you
Regards!!..
Anonymous
Level 3:
Genius:
  • Master 1,847 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1847
Questions
Helped
553261
Points
4940
Check the wall socket, is it working fine.
  • Anonymous Aug 24, 2008
    check the compressor is it generating any heat and sound.
    check the wire connection from the wall to the fridge.
I can't identity my Engel fridge. I can read mt40 something -c4
Please call Engel and ask them for an email address that you can send a picture of your fridge to: 1 561-743-7419. They will be able to help identify the fridge model for you. Thank you.
3answers
Sub-zero Refregrator 352 Freeze cooling properly, but Refregrator only cools to ~50f. Stays off until ~70f, when set at lowest temp (10).
Fans working and air flowing thru the cooling coils?
The inside fan warms the evaporator, or cooling coil. If this coil does not go thru a defrost cycle or if there is ice build up to the point no air gets across it, that could be the scenario.Then it would need defrosting, or inspection to make sure there is free air flow both inside and outside the fridge, including the defrost timer if present. If all this checks out ok, then the refrigeration circuit is to be looked at by a technician.
My sub zero model 561 refrigerator side is not working
The fridge side or the freezer side? not cooling, or just no lights? Nothing is cooling or lighting?
1helpful
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
1helpful
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Some features stopped working
Try running system restore, then a virus scan.
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
2helpful
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Fridge not cooling
two comperssor ... check the thermostate ..or make sure there is power to the compressor...
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
