20 Most Recent Sub-Zero 650 / O Bottom Freezer Refrigerator Questions & Answers
After the power outage my Sub Zero 650's control panel is stuck on showing
Hi, It's possible that your refrigerator could have it's own capacitor/battery that needs to be charged to a certain level before every portion of your fridge functions again. You can give the fridge 1.5 hours to be plugged in before checking your freezer temperature again. If that does not work, please call sub zero by dialing 1 (800) 222-7820 Thank you.
7/31/2022 8:18:29 PM • Sub-Zero 650 / O... • Answered on Jul 31, 2022
14answers
Leaking sub zero 650
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
6/11/2022 11:11:50 PM • Sub-Zero 650 / O... • Answered on Jun 11, 2022
7answers
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
10/24/2020 2:24:49 AM • Sub-Zero 650 / O... • Answered on Oct 24, 2020
Sub-Zero 650 ice maker not working - makesa loud clicking noise
Sounds like the gear is failing in the ice maker unit. I would replace it.
5/31/2019 10:17:29 PM • Sub-Zero 650 / O... • Answered on May 31, 2019
2answers
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
11/22/2017 7:50:17 PM • Sub-Zero 650 / O... • Answered on Nov 22, 2017
2answers
What controls the condenser fan?
Your condenser fan motor should run any time the unit is calling for cooling, if the compressor is running, the condenser fan should also be running. Hope this helps....GOD BLESS....Randy....
11/7/2017 11:04:45 PM • Sub-Zero 650 / O... • Answered on Nov 07, 2017
I have a Sub-Zero 650/F that's about 12 years old. Recently, the freezer temp has been creeping up from the usual -3F, and recently I've noticed that when the ice maker is on, the temperature
Turning the icemaker on will not have anything to do with a defrost issue. Sounds like the icemaker is culprit.
10/5/2017 2:48:32 AM • Sub-Zero 650 / O... • Answered on Oct 05, 2017
I have a sub zero model 650/s2,it is about 6 years
Could be thermostat is not working properly Search Over 2 1 Million Appliance Parts
9/19/2017 1:23:13 AM • Sub-Zero 650 / O... • Answered on Sep 19, 2017
Ice maker not making ice - repair costs?
If you have a warranty with Sub-Zero 650, I would call them to come and take a look at it; it may be better to have them fix it.
7/11/2017 8:51:05 PM • Sub-Zero 650 / O... • Answered on Jul 11, 2017
A CUSTOMER OF MINE HAS
It sounds like either an airflow issue, like dirty or restricted coils, or a fan not working well. Or it may be low on charge.
6/9/2017 9:48:55 PM • Sub-Zero 650 / O... • Answered on Jun 09, 2017
2answers
Can you use auto air conditioning R134a to fill the unit?
Hi, Different connections but this is the same freon. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/20/2016 1:18:30 PM • Sub-Zero 650 / O... • Answered on Aug 20, 2016
2answers
Contol panel lights are no longer lit; why?
Hi, Control panel lights are behind the panel, so if the compartment lights are on the panel is lit. If no lights are on when you open the door, check your door switches as you may find the light switch has failed. Look there first, no lights, possible just a bad switch. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2/2/2016 7:13:19 PM • Sub-Zero 650 / O... • Answered on Feb 02, 2016
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
672 questions posted
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Sub-Zero Refrigerators
Most Popular Question
subzero 650 drip tray full water factory
  • Refrigerators
