Computers & Internet Logo
Carmen Vargas Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My compaq desktop computer and keyboard are messed up, suddenly every letter i enter is a number i am using windows xp
  • 2 more comments
  • Carmen Vargas Jul 01, 2011
    i did what you suggested not helping please help i even tried hooking up another compaq keyboard
  • Carmen Vargas Jul 02, 2011
    which function key there are12
    Well I found the answer on another tech support site it was the constant guard security from comcast that was the culprit they said to get rid of it in add and remove programs and it worked
    no this did not work but I fixed the problem with advice from another tech support site
    I got rid of Constant Guard Security from Comcast in add and remove programs rebooted and yea it worked Thank You anyway
Anonymous
Level 3:
  • Master 1,555 Answers
  • Posted on Jul 01, 2011
Anonymous
Master
Level 3:
Answers
1555
Questions
0
Helped
438970
Points
4726
I think it's probably the keyboard layout. Try going to Start->Settings->Control Panel and double click on Regional and Language Options. Make sure the Regional Options tab is set to English. Then go to the Languages tab and click on Details button. Make sure that the Keyboard has US under it.
  • Anonymous Jul 01, 2011
    ok, hit Num Lock key while pressing Fn key. This will give letters back.
My pc have problem in booting, how can i solve this problem, am using compaq = window xp professioner
Restart your pc and sudden pres DELETE kex.opening BIOS windo.opening EXIT option and using LOAD OPTIMISE ENTER.Press Y.then pressF10 key enter
2answers
When typing I can see letters with 3sec delay on the screen
This is not keyboard issue
if you are using windows xp , do the following
goto RUN
type %TEMP% enter
and delete all files, then restart computer
then you can check
thank you
Error code 0000135 unable to locate component basesrv not found
  • Insert the Windows OS CD in the CD drive of your computer, and then restart your computer.
  • 2 Press "R" on your keyboard when you see the Windows XP( if your OS is XP) "Welcome to Setup" screen. This will start the Windows XP recovery console. If you are asked to enter the administrator password, type it and press "Enter."
  • 3 Type the following commands one by one, without quotes, at the command prompt, and then press "Enter."
    "EXPAND drive_letter1:\i386\user32.dll_ drive_letter2\windows\system32"
    "EXPAND drive_letter1:\i386\userinit.ex_ drive_letter2\windows\system32"
    Replace drive_letter1 here with the CD drive letter of your computer in which the Windows XP setup CD is present (for example, E:), and drive_letter2 here with the letter of the drive in which Windows XP is installed on your computer
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
I'm trying to copy the ntldr files from my xp disk but everytime I type in the copy command I get "access is denied". Is there something I can do without losing everything cause I had a lot of...
hi
follow these instruction exactly . this will work
If you get the "NTLDR is Missing" error, follow these instructions:
1. Load Windows XP CD into CD drive.
2. Make sure BIOS is set to boot to CD drive.
press F8 or F11 to get into BIOS
3. Boot the computer from CD.
4. At menu, press "R" to load Recovery Console.
5. Select the installation to be fixed.
*The following instructions assume CD-ROM is labeled as drive D and the hard drive partition the windows installation is on is labeled as drive C. Replace the letters accordingly.
6. Type "COPY D:\i386\ntldr C:\" and press ENTER.
7. Type "COPY D:\i386\ntdetect.com C:\" and press ENTER.
8. Remove CD and type "EXIT" and press ENTER (to reboot your computer).
God's speed
1helpful
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
1helpful
2answers
Dell computer running windows xp will not boot. NTLDR compressed
best thing to do if you can get one is a propper install disk and then follow these instructions..
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows Xp compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
I got my compaq desktop pc locked
Try starting your PC in Safe Mode.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe mode takes a while to load but once it is loaded, I think you can use control panel to get to "add/remove programs" - then hopefully you can uninstall "screen on password"
Ntldnr is missing
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini Use the Recovery Console loadTOCNode(3, 'summary'); 1. Use the Windows xp disks to restart the computer 2. At the Welcome to Setup screen, press R to repair the Windows xp installation. 3. Press R to repair the Windows XP installation by using the Recovery Console. 4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. 5. Type the Administrator password, and then press ENTER. 6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM. 7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," copy drive:\i386\ntldr c:\
copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Ntldr is compressed
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
Compaq Keyboard Problem
Hello Ganguly
You likely need to enable legacy (older technology) USB devices in your desktop computers' BIOS.
How to enter the BIOS of your particular computer will depend upon its motherboard and BIOS.
HERE is a link to a site w/ a listing of BIOS manufacturers and how to enter their BIOS.
You can identify your motherboard and BIOS by running the free BELARC ADVISOR PC audit utility found HERE.
The BIOS is entered normally during POST (right after powering on or restarting the computer - while the screen background is still black).
It is during this period that you must strike the key or key combination required to enter the BIOS.
If you need assistance w/ this, please, run the BELARC ADVISOR PC audit utility and let us know what motherboard & BIOS is installed on your computer. Or, if yours is one made by a major manufacturer (Gateway, Dell, IBM, etc.), let us know the manufacturer, model, and serial number or service tag of the computer. W/ that information we'll likely be able to find out how to enter your computer's BIOS.
Please, let us know if this response was helpful for your or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
