20 Most Recent
Compaq EVO D5S SFF Refurbished Desktop Computer Questions & Answers
My compaq desktop computer and keyboard are messed
I think it's probably the keyboard layout. Try going to Start->Settings->Control Panel and double click on Regional and Language Options. Make sure the Regional Options tab is set to English. Then go to the Languages tab and click on Details button. Make sure that the Keyboard has US under it.
I have a Compaq Evo
Three beeps at POST (startup) may be caused by an issue with your video card. Check to make sure the video card is seated correctly. If you have another video card, you can try it to determine if the current video card is faulty.
I facing no display, but led glows in red what i8s
This issue can be caused by any of the below possibilities.
1.Monitor is not on
3.Connections not connected properly.
3.Hardware issue.
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly
Make sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
PLEASE RATE THIS ANSWER IF SOLVED.
Replaced the power supply now put power onto the
There seems to be a faulty connection somewhere, make sure the power supply has a connecter for your motherboard to give it some power.It all depends on the type of power supply you have aswell and the motherboard you are using , If your power supply does not have a connector for your system fan port on your mainboard then you should either change your motherboard or your power supply, If you refereing to a System chassis fan the see if you can try to connect it directly to one of the molex connectors on your power supply.
Computer loading
AS what you have said computer start over and over again. this was due to the system conflict or hardware conflict.
The solution of this is to restore all the setting by completely restoring using the installation disk.
Or reinstall the windows operating system.
procedure in windows installation can be found here:
http://support.microsoft.com/kb/316941
Hope you do this in order, please tell if whatever happen.
melnavz
Please Help Me.............................
Doesn't really make a difference whether new or used your machines. What matters is the preventive measures as well as the regular maintenance required to keep it running at top condition.
There are several methods of maintaining an efficient PC meaning to keep it running as fast as it originally was when you got them. Before I can make any suggestion, please add some more information by replying to the queries below:
1. What is the Operating System of the computers?
2. Are the machines tied to a local networking?
3. Do you have access to Internet and in what manner are you connected?
4. Do you have any anti-virus, anti-spyware, anti-malware running?
5. Do you have a user account other than the Administrator for each PC?
6. For what purpose are the PCs used (gaming, office application, internet surfing)?
7. What other devices are attached (brand/model/capacity of video card, CD drives, bluetooth, infrared, webcam etc) to the machines?
8. Are you using some sort of a Cafe Manager program?
9. Do you have a dedicated server other than the 17 units?
10. What software utilities are you using (Norton, System Mechanic, TweakUI, Registry Cleaner)?
11. What other programs are running constantly (Chika, Yahoo Messenger, ICQ, etc)?
Soon and upon receipt of your reply, we can start figuring out corrective measures and other actions your onsite technician can perform to prevent future slowdown and maintain efficiency.
Good luck and kind regards.
Compaq 510s sff. Graphics Card
Hi Mikey
You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP
1- turn your computer off (Shut Down)
2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen)
3-find your desplay/graphic or anything that is related to graphic.
4- Change it to AGP
Now it should work but if it didn't work:
1- Faulty Display (Monitor)
2- Not compatible graphic card(rearly)
3- loose or damaged cables
4- Damaged Motherboard
please let me know of your progress
Kind Regards
Problems
try pressing repeatedly F8 while its booting and if its not badly damaged you will get into safe mode.
When in select last known good configuration and press enter on the line for a reboot.
It should if theres no major faults go into windows as normal, if not then there is someting more drastic at fault.
Manufacturer of Compaq Evo Motherboard
open it up and the mother board manufacturer will be printed on the board
any mother board can be used as a replacement and if it needs replacing update it so that a later chip can be used
it is cheaper to replace the mother board , power supply , memory, chip than to buy a new computer
and hard drives are now solid state and do not have any spinning bits to fail
talk with a computer repair shop and get ideas as to how to proceed
you will probably find that with a rebuild you will save at least 25% off the price of a new store model pc and get a better unit to boot
Cmos date time not set
Hold diwn F2 key while booting. This should bring up the screen you need to set time and date. CMOS is your motherboard battery.
How do you enter power-on password key
Go to BIOS then go to Security and one drop down menu will come then click on enable the Power ON Password and press save button and the Power ON Password option will come after that enter the password two times and save that.
Now u have succesfull addes the power on password.
Solve hang problem
There are some possibilities through you can increase performance and solve ur hanging problem.
1. Open command prompt and type chkdsk and press Enter. after few seconds it will ask for Y/N and type Y and press Enter.
2. Type defrag c: -f and press enter. It ill defrag your c drive.
3.Click on Start>All Programs>Accessories>System tools>desk Cleanup and it will scan the temp files and will delete them after clicking on OK after scanned.
4. If this not solve the issue then run the system in safe mode and check is it hanging on the safe mode then there might be some issue in hardware otherwise needs to install the OS again.
