SOURCE: MFC-210C
First ensure that none of your inkjet cartridges are empty or near empty. The machine will not perform cleaning if any cartridge is too low on ink. If the conditions are met the machine at least attempt perform the cleaning function. There is no guarantee that the print quality will improve on the first try.
SOURCE: Computer Won't Recognize Printer
It is not the major problem, it's the problem of OS system don't worry.
U, just reformat the harddisk again and install the fresh correct right License cd u use, to format the harddish Corrupt don't use the wrong verson or the corrupt cd. Beuz sometime the beta verson or wrong cd might not install the required program to the OS that support the hardware install in your system. fresh & ok cd u use to install OS cd. I sure that when u install fresh OS in your system there be no problem at all.
After installing the OS system and get install the mother board chipset cd which u got when u purchase the system install all the program automatically one by one& step by step. In that cd all the program will be install automatically that program will install which u system required.and then restart.the system.
After restarting the system go to device manager see all the device r install perfectly. After that u plug the printer cable with ur system the message will appear ( found new hardware) in ur screen and then fellow the instruction and install the printer program cd in ur cd drive and then continue fellow the instruction manuly.
I sure it be joyfull.
SOURCE: Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
SOURCE: brother mfc control center.
ok so its a common problem just take it to the store it won't cost you a dime.
