20 Most Recent Brother DCP 115C All-In-One InkJet Printer Questions & Answers
Downloaded service & repair manual for brother mfc 5840CW- my unit. Will follow repair directions to check the memory then replace required parts. Will be cheaper and faster than finding a repair shop and paying as much as the macine to fix it! Rip off prices for repairs today on units so they can get you to leave them and buy a new one. Then they fix the unit and sell it "refurbished"- not mine!
Your information on clearing memory, the ink cleaning codes and taping the cartridge from over cleaning was good. Thanks for the help!
Brother DCP 115C... | Answered on Sep 17, 2019
Do not use single paper in paper tray use multi papers and also clean paper feeder
Brother DCP 115C... | Answered on Apr 13, 2019
High probability it is a waste ink count or "error 46" code fault. There are purge count reset codes available on line, but you should also remove and clean out the waste ink chamber. It is a messy job and given the age of the machine, you may be better off replacing it
Brother DCP 115C... | Answered on Nov 22, 2017
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Brother DCP 115C... | Answered on Sep 13, 2017
Dcp-150C, clean unable 46
Brother DCP 115C... | Answered on Aug 03, 2017
Using copy cartridges this is a common issue. Always use genuine cartridges.
Brother DCP 115C... | Answered on May 17, 2017
Brother DCP115C Code: 50, 51
Description
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Brother DCP 115C... | Answered on Sep 09, 2016
Check out page 13 of the manual. Change the setting to grayscale.
http://download.brother.com/welcome/doc000417/BH3e_UkEngSoft_C.pdf
Brother DCP 115C... | Answered on Apr 28, 2016
No you don't have to take it to be serviced. There is a work around for this. It is not an ideal work around but given the low cost of these printers they probably aren't worth spending the money on at a service center.
OK the Fix is, you simply turn OFF BiDirectional printing in the printer driver settings.
The printer will then print correctly.
Also I'm sure if you could obtain the service software for alignment it's probably not beyond the abilities of a back yarder. :)
Hope this helps.
SiliconJaguar
Brother DCP 115C... | Answered on Nov 17, 2015
plz check the manufacture website
Brother DCP 115C... | Answered on Oct 18, 2015
my brother dcp 150 when going to print it says unable to print any help?
Brother DCP 115C... | Answered on Jan 12, 2015
De-install & reinstall it (download from solutions.brother.com) Windows 7 is the most friendly OS for Brother printers.
Brother DCP 115C... | Answered on Dec 09, 2014
there must be a code (46?)
Brother DCP 115C All-In-One InkJet Printer Logo
507 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
printer brother dcp115c unable clean
  • Office Equipment & Supplies
