My printer starts to print, but paper wont feed. Please help! My Lexmark 5150 printer won't pull the paper through the feeder. I found a white roller piece in the printer. It appears that one of the wheels have broken off. Can this be fixed? The printer is in great shape other than this. I've tried taking the paper out and feeding one sheet through one at a time, this worked for 2 sheets but quit after that. It acts as if it wants to pull the paper through but it can't grip it. Please Help
Many resale shops such as Salvation Army, Value Village, Purpleheart Veterans, Americas Disabled, etc, have old printers and on half price sale days can be had for five or ten dollars.
I am sorry to say that it will be more expensive to fix this printer than to get a new one. the only thing you can do is to see if you can get a used one somewhere and use that for parts
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1. Remove
the sheets of paper from the feeder.
2. Grab a
flashlight and look inside the feeder for any debris or foreign objects.
3. If
you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4. If
feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
cartridge area is clear, close the cover.
7. Re-brick
your printer. Pull out the power supply, black box where the power cord is
plugged in at the back of the printer, and put it back after 30 seconds.
8. When
the printer turns on, reinsert the cartridges and load some paper. Try to print
a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Leading
1.
Remove the sheets of paper from the feeder.
2.
Grab a flashlight and look inside the feeder for any debris or foreign objects.
3.
If you're willing and physically able, you may also turn the printer over. Any
4.
If feeder is clear, place the printer back on the table, open the printer cover
5.
Check the cartridge area for any obstructions/debris in the cartridge carrier's
path or the paper path.
6.
If cartridge area is clear, close the cover.
7.
Re-brick your printer. Pull out the power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Re-brick
8. When
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also
turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the
table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris
that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet
to reset it.
load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
