There is a lot of problems that can cause the light to turn red, such as paper jam, low toner, full waste toner tank, etc. The only real way to know what the printer is detecting is to use the smartpanel utility program. It should be able to tell you what the printer fault.
Usually the reason for the optical sight glasses are dirty in the printer in the vicinity of the tank odpasowego. They are made of plastic and wear an hemisphere shape. If Z toner everything is in order and the drum is at 99% of it is the main problem with this Samsung printer.
