Hold down the [0] for 7 seconds and press [start] without releasing the [0] you will be prompted for a password. enter [6789] and press confirm select system settings followed by administrator log in/set up and change the password back to [11111]
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Go to Xerox.com click on support and drivers, then enter 450cp into the search box, then click on documentation. You can download that guide from that site.
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
Initial Action
Refer to BSD 16.1.
Power OFF/ON
Procedure
Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
