20 Most Recent
Xerox WorkCentre Pro 123/128 Printer Questions & Answers
Xerox WorkCentre Pro 123 linux driver ?
if you open your web browser, put in
www.xerox.co.uk, go to cusomer support then to suport and driver,
there put
- WorkCentre M123/M128 and then your operating system. From there you should find the driver package for the linux system
My problem "Error 116-365"
116-365 Spool Fatal Error RAP
Due to a fatal error that occurred in general SPL processing, subsequent processes cannot be
performed.
ProcedureIf the problem was not resolved by turning the power Off/On and the same error continuously
reoccurs using CE Log, carry out the following procedure:
- Pull out and insert or replace the DIMM.
- Retrieve the Troubleshooting Log (apply the specified method).
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Error code 010 398
The only suggestion I have would be to reboot the machine and try again. In a lot of cases any error codes AKA Fault Codes begining with 010- point to a major mechanical error.
Nothing specific sayiing so in my research, if a reboot doesn't bring the machine back up your next step would be to contact your Xerox service technician to go onsite to resolve.
If you're not holding a maintenance agreement on the WCP device
Check with the person you bought the device from to see if there is anything they can do to assist.
The WCP device you have is an older model and if you are experiencing problems with it on a regular bases you may want to contact Xerox and see if there is a possible upgrade strategy they can assist with and get you into a newer model with out breaking the bank so to speak. ????
I hope this helps.
2 sided printing problem
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
