Neff H5642 Convection / Microwave Oven Logo
Posted on May 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The oven cuts out after counting down from 1 minute at 38 seconds and no heat
A Miller
Level 3:
  • Neff Master 8,404 Answers
  • Posted on May 14, 2011
A Miller
Neff Master
Level 3:
Answers
8404
Questions
Helped
2053353
Points
24677
No heat is typically failed micro switch's that act as the door safety interlock. Remove the cabinet to find the tiny switches. Test them for proper action. Should show open or short depending on whether the door is open or closed.
Miele M 625 EG Microwave Oven
A malfunctioning control panel or membrane can cause erratic behavior in your microwave oven. If the control panel is not registering the start command correctly, it may interrupt the cooking cycle. Try cleaning your membrane and control panel with a soft and damp cloth to remove the dust.
If cleaning doesn't resolve this issue, try resetting the microwave oven by unplugging it from the power source for a few minutes, and then plugging it back in.
The microwave may not generate the required heat to cook the food properly if the magnetron or high voltage capacitor is defective. This could lead to the timer counting down without any heating action.
1helpful
300 is not 3 minutes on a microwave.
as you stated...microwave counts down in seconds.
300 seconds is 5 minutes 180 is 3 minutes.
When I try to use the microwave, it counts down the minutes and seconds I set it for, but does not heat food. The turntable doesn't spin either.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
1helpful
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
1helpful
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
1helpful
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
5helpful
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Top Neff Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Tracy
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
