20 Most Recent
Neff H5470 Microwave Oven Questions & Answers
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
There is an unpleasant smell (like rotten
Unfortunately the fault can be that there is some organic matter that seems to cause the issue , it can be sometimes insect or small creatures that have caught into the magnetron high voltage and is cooked.Also it can be insulation failure on the magnetron that causes the smell on heating of the material. In all these cases the oven must be opened out- taken out and observed.
If the fault is in the magnetron, or the capacitor that is leaking or an insulation of the transformer, then it must be replaced. But in the first place check if you can remove the unit with your resources.
