20 Most Recent Maytag MMC5000 Microwave Oven Questions & Answers
13answers
Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
11/2/2018 12:42:05 AM • Maytag MMC5000... • Answered on Nov 02, 2018
2answers
Won't heat
its likley to be a burnt out magnatron (thats the part that heats the food up) if its burnt out then a fix would cost as much as a new microwave would there is nothing you yourself can do to fix it and just trying to could kill you so to be on the safe side drop it in the shop for repair or bump it and buy a nice new one
2/18/2015 7:55:35 PM • Maytag MMC5000... • Answered on Feb 18, 2015
2answers
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cov
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/5/2014 11:49:48 AM • Maytag MMC5000... • Answered on May 05, 2014
Stopped working
One or two of the door switches are more than likely defective.
3/27/2012 10:38:04 AM • Maytag MMC5000... • Answered on Mar 27, 2012
My GE JVM1750 microwave oven
Hi
The issue is with the door switch or the thermostat located near the turntable motor is bad and should be replaced. If it was the fuse the unit will not even work, so I believe it is the door switch and I don't think that the control can go bad. Hope this helps...please post back for further assistance.
Daniel
10/20/2011 1:25:17 AM • Maytag MMC5000... • Answered on Oct 20, 2011
What would cause a GE Spacemaker above the stove
The magnetron tube inside the oven is bad have it checked
10/2/2011 1:29:30 AM • Maytag MMC5000... • Answered on Oct 02, 2011
My microwave was just working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/22/2011 2:45:18 AM • Maytag MMC5000... • Answered on Sep 22, 2011
Maytag MMC5000 Microwave Oven Logo
125 questions posted
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
ge microwave starting arc see arcs
  • Microwave Ovens
