20 Most Recent Maytag MMV4205 Microwave Oven Questions & Answers
Damaged or defective latch. Repair or replace.
Maytag MMV4205... | Answered on Aug 06, 2019
diode is connected from condenser to earth look to the right side bottom just under fan beware for a nasty shock
Maytag MMV4205... | Answered on Jul 16, 2019
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
Maytag MMV4205... | Answered on Jul 05, 2018
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
Maytag MMV4205... | Answered on Jan 14, 2018
Check for damaged, contaminated door switches/clips.
Maytag MMV4205... | Answered on Dec 17, 2017
There are 2 fuses inside the cabinet. One is for the clock and turntable. The other is for the high voltage transformer and the microwave module. If this fuse is blown either the transformer is shorted or the module has failed to cause the fuse to blow. Parts and Labor can get close to the cost of a new one, so get an estimate so you can have information to make your decision
Maytag MMV4205... | Answered on Nov 09, 2017
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
Maytag MMV4205... | Answered on Oct 09, 2017
Sounds like the on switch for the fan is fused in the on position. You may need to replace the switch
Maytag MMV4205... | Answered on Oct 07, 2015
Use kitchen timer not cooking timer, it's written on your oven timer pad. I did that before
Maytag MMV4205... | Answered on Jul 06, 2015
inside the case
Maytag MMV4205... | Answered on Jun 17, 2015
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Maytag MMV4205... | Answered on Jul 29, 2014
The latch may be broken or defective and will have to be replaced.
Maytag MMV4205... | Answered on Jul 08, 2014
The Magnetron Tube can be replaced but you should read the
link before
Consumer Complaints & Reviews
Maytag MMV4205... | Answered on May 20, 2014
Maytag MMV4205 Microwave Oven Logo
298 questions posted
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
maytag microwave problem everything
  • Microwave Ovens
