Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
