20 Most Recent Panasonic PT-LB50U Multimedia Projector Questions & Answers
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Panasonic... | Answered on Jun 18, 2016
lamp bulb broken or bad connection to source
Panasonic... | Answered on May 27, 2014
Menu
security
enter
input password on---off
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Panasonic... | Answered on Feb 11, 2014
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Panasonic... | Answered on Sep 15, 2013
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Panasonic... | Answered on Mar 16, 2011
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Panasonic... | Answered on Jan 25, 2011
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Panasonic... | Answered on Jan 21, 2011
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
All you need is in the manual.If you dont have a manual ,
check their website and do a search on your model number.
Download is free.
Panasonic... | Answered on Oct 11, 2010
Have you installed the lamp?
Panasonic... | Answered on Dec 06, 2009
Code E3-01: Toner Bottle Motor rotation
  • Toner Bottle Home Position Sensor connector is disconnected
  • Toner Bottle Home Position Sensor is defective
  • Toner Bottle Motor connector is disconnected
  • Toner Bottle Motor is defective
  • Toner Bottle Motor Drive Mechanism is defective
  • Toner Bottle is installed incorrectly
  • SPC PCB connector is disconnected
  • SPC PCB is defective
Panasonic Office... | Answered on Jan 04, 2020
Call your local Panasonic servicer and report code 3.
Panasonic Office... | Answered on Dec 12, 2019
Panasonic PT-LB50U Multimedia Projector Logo
19 questions posted
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
lamp reset panasonic pt lb50u projector
  • Office Equipment & Supplies
