20 Most Recent
Dell 1409X DLP Projector Questions & Answers
How can i clean the filter
This is probably the lamp. If you replaced the lamp then you need to reset the lamp counter in the menu settings. You should clean the filter out as well.
Color wheel flashes multiple colors
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Power light
hi,
If the lamp light is solid orange then, the lamp of your projector is faulty. You have to repalce the lamp.
ok
Dell 1409x is dead and
Do you have any LEDs indicating that the projector is getting power?
If not, it is unlikely to be the lamp which is the problem and more likely a problem with the mains supply outlet, extension cable, mains input cable, mains input fuse (all easy to check) or maybe the internal power supply (requiring professional repair).
If there are LEDs lit they will indicate a fault, for which you will either need to post the exact sequence and timings, or consult the manual.
