The paper may not be 'lifting' as you push the paper tray in.
Open the front 'door' of the printer, remove the toners, so that you get a clear view of the paper tray. Is the paper in contact with the pickup rollers ?
The paper tray lift mechanism can wear and there is a small plastic component that can break. Replacing the paper tray will probably do the trick and fixe this.
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn /
3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn
/ 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's
operator panel, perform the following steps:
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure
1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator
Panel
To verify the paper type matches the type set in the printer's operator
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the
MPF only.
Verify the printing preferences on the Dell™
3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with
the correct paper size, perform the following steps:
The Printers and Faxes
window appears.
The
Printing Preferences window appears.
This sets the size and tray
defaults.
Verify the Paper Size From the Printing Application Matches the Designated
Printer Tray
To verify the paper size from the printing application matches the designated
printer tray, perform the following steps:
Verify the Paper Source From the Printing Application Matches the Designated
Printer Tray
Do not replace any printer hardware as this is not a printer hardware
issue.
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
SOURCE: getting message to load tray 1 A4. load with
A4 NOT LOADED IN ANY TRAY the product is hp c3100
SOURCE: Brother MFC-9840CDW says no paper when trying to
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
