Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
