Hello
Just unplug the base unit from AC wall power socket for a while, say for about 5 minutes or so, replugh the base unit to power socket again. Place each handset on it and synchronise it with the base unit. As you put it on, you will hear a beep sound. Now the ahndset ahs been synchronised with base unit. Do this for the other two handsets. OK.
Have you tried just the battery and power led for 24 hrs? A new baterry needs initial charge period before use and could be taking the majority of the power supplied by the adaptor, hence the freezing.
I WAS TOLD THE PROBLEM WAS PROBABLY THE BATTERY. AS THE BATTERIES ARE THREE YEARS OLD AND CONTINUE TO POWER THE UNIT I CAN'T BELIEVE IT'S THAT. IT STATES THAT THE BATTERY SHOULD LAST ONE YEAR AND WOULD INDICATE "LOW BATTERY". THE PHONES ARE ALWAYS IN THE CRADLES AND POWERED UP. I TESTED THE OUTSIDE LINE AND FOUND NO NOISE. AS THE BATTERIES ARE $20 EACH, I BOUGHT A NEW PHONE FOR $10. SINCE THEN, I HAVE RE-CONNECTED THE OLD UNIDEN PHONES, BOTH IN MY HOME OFFICE AND IN MY BEDROOM AND THEY SEEM TO WORK JUST FINE WITH A MINIMUM OF NOISE. THIS ALL OCURRED AFTER SEVERE SNOW, WIND AND RAIN STORMS.
THANKS FOR YOUR RESPONSE.
TERRY ANDERSON
Mine did that and I just futzed around with it (take the battery out, then put the unit in the charger). Stuff like that. Also watch the power supply for the charger! Mine read 5V ok until I plugged it in. Then it dropped to 4V. I bought a whole new radio before I figgured it out. (I'm using an old PC PS for the 5V now.)
