20 Most Recent
Philips CD-150 Questions & Answers
I have Phillips CD150 handset.
there is a problem with the Base unit (Charger), repair man said that the main IC should b changed which is too costy, better to buy another set.The handset of the faulty unit can be paired with the new set.in short the handset shows what it receives from the base (charger) so it has no fault and may be used with another set
I cant dial, the screen
Hello
Actually Philips CD-150 is a phone . If you want to unlock the keypad Press and Hold [ * ] button on the handset for more than onsecond. OK
How do I listen to
You need to contact your service provider and set up voicemail with them.
HI
I have had this
turn it off and on a few times if that dnt work look up your phone online
