Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error : 52 scanner error turn off then on Printer model HP Laser Jet M1522nf
Ed Mac
Level 3:
  • Master 731 Answers
  • Posted on Nov 25, 2010
Ed Mac
Master
Level 3:
Answers
731
Questions
0
Helped
252441
Points
2239
Turn the unit off for at least 30 seconds before power it back on.
If you have the unit on a surge protector ... remove it as these unit can create low voltage problems for laser printers.
If the problem persists ( and there's a 50-50 chance it will) my 20+ years experiance with HP printer says you need a new scanner assembly. HP Part# RM1-4724-005CN $90-$120 + installation
It may be better to replace the printer as a used one can be bought for about $250
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps:
·Turn off the printer
·Wait for 30 seconds and then turn on the printer
·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced
·In case the error is still being shown, the Scanner/Laser assembly may also require replacement.
Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
HP LASER JET 2300 52.00 ERROR
Tallon41
1helpful
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
2helpful
2answers
Hp Laser jet M1522nf show" 52 Scanner error turn off then on" give me solution urgent
52 Scanner Error The product has experienced an internal hardware error.Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see www.hp.com/support/ljm1522 or the support flyer that came in the product box.
This is the internal laser scanner, if the error persists the scanner will need to be replaced by an HP authorized technician.
3helpful
HP Laser Jet 4 Plus error code 52 What do I do now?
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
1helpful
4answers
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
k24674
Grand Canyon Tech
Grand Canyon Tech
