Hello there
First your f-1 error code
The F1 Error
On a number of ranges this can mean a number of things, the most common being
a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using
a recent Maytag range it may pay to test the oven sensor as described above
as this may cause an F1 error if faulty (may apply to some other ranges as
well) this is not a common cause but is worth discounting.
To check the ERC and touchpad
And the 8 error is also conclusive along with the f-1 meaning that the erc or electronic range controle is faulty and should be replaced
Whirlpool gold range gas igniter switch keeps firing after it is turned off what to do ?
