Belkin (F5D5231-4) Router Logo
Posted on Sep 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help trying to connect my router to my laptop belkin basic
Resolution IT Dubai
Level 3:
Guru:
  • Master 541 Answers
  • Posted on Sep 05, 2010
Resolution IT Dubai
Master
Level 3:
Guru:
Answers
541
Questions
Helped
231563
Points
1629
Hi Friend,
            Please follow the below link, where you can find step by step process for the Router Installation
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
Regards,
Aysaam
Cant connect kindle fire to wireless
tRY HERE http://www.amazon.com/gp/help/customer/display.html?nodeId=200729310#connect
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
I need help with belkin n150 model F7D1401 V1 ..i can't connect to my network..i have a Huawei SmartAx Mt 882 modem..and i want to connect my network, wich is an ADSL one, to my computer..I can't...
Your MT 882 modem most likely has a DHCP Server that will interfere with the ip address of the router. Did you plug the Router directly into the laptop then go to dos prompt and type in ipconfig/renew . Or reboot the laptop !
Then type in 192.168.2.1 into browser
You need to work out the IP address of your 882 modem and then change the dhcp server leases on it to start at 20 like it might be 10.0.0.1 to 1.0.0.254 or it could be 192.168.1.1 to 192.168.1.254 .
if you are planning on using both devices on the network !
Make the Modem DHCP start at 192.168.2.20 to 192.168.2.254 and then make the Belkin router / modem ip address be 192.168.2.2 and the 882 modem 192.168.2.1 if you plan on using the two devices together on the network disable the belkin dchp server.
if you are using just the belkin then the reboot or ipconfig/ renew will be all you need .
I need help,now ! I want to know,how can i change SSID ? I've bought Basic Wireless Modem Router part# F7D1401V1 and can used it now but i need to change SSID only ! ...
Connect a LAN cable from Belkin to your laptop/computer'sLAN port, open a browser on your laptop/computer and enter the Belkin'sconfiguration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
I am trying to use my lap top will not connect to the wireless belkin router we just installed
check,if you are able to connect other laptop,to the same wireless router if yes issue must be with the laptop itself check,if the wireless switch is enabled if enabled, uninstall and re-install the wireless driver from the device manager
if issue is with the router,try reseting the router
2answers
How do I hook up a router, I have wireless internet already
If you have wireless internet already, then go to Belkin's website. Most electronic devices nowadays have manuals in PDF format on their websites. Different router manufacturers usually has a different setup protocol for their devices.
6helpful
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
