20 Most Recent
Gateway 802.11g Wireless DSL/Cable Router [ Belkin F5D7230-4 Wireless ] (108995) Questions & Answers
My Belkin G+ router is set up but not working
Based on your description, the only thing that I can think of that would be the issue is a router to modem compatibility issue. If it's, please attempt to use the same type of modem as is used in your home to help overcome the issue. Thank you.
Lost disk to my belkin router model f5d7234-4 how
You can configure your router without disk too.
Follow below instruction.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
I am trying to set
Hi. First, make sure that your network is recognized by your anti-virus/firewall as "safe zone". Then check if your laptop is getting a correct IP from your network. To check your IP, open "Network and Sharing Center" then click "Change adapter settings" (with red arrow in the pict) then right-click "Local Area Connection" select "Status" then click "details" tab. Since you already joined your laptop to home network, you just need to change "network location" by clicking the link below "Network" (shown in the pict) then select "Home Network". Let me know if you have more questions. Good luck.
Pin no fo belkin 802-11g
What do you mean by pin no? Are you trying to make a wireless connection between laptop and router? I am assuming then you need the key for the router? If you don't know the key you will have to access the router directly via Ethernet connection and reset the protection key. If you need further assistance please let me know.
Thank you,
Lee
I cannot get it to rest
hi
1)
go to explorer and type (
http://192.168.0.1)
it will alove you to acsess you router
from thaer you can resetup
2)
back site of router thare will be small holl just put small pin press for 10 cecont it will restep all fungtions
The DVD instructions ask for Cnnection type,
For that you need to access your router.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then WAN settings configure your router as pppoe connection then add user name and password then Enable DHCP then save and restart router.
My belkin router wont let my neighbor's PC get
Is there any other computer online ?
If not then check the settings of the router .
If you have another computer online ( wired or wireless ) which is able to go online using the same router then check the IP address on the computer which is working.
is it a wireless computer ?
If it is a wireless computer then check whether it is connected to the wireless network or not.
Check the wireless settings of the router also
Click Here for more info abotu wireless networks and router
I lost the disc to setup my belkin g router
You can connect to the router to make any changes by typing this number: 192.168.2.1
Put in your administrator id and password and you are good to go to make any changes you want.
Hope this helps
Robotek
it means that if using the dhcp option then he send the ip address to your pc or laptop but you give the static then this problen will not get it
Laptop wont connect to wireless belkin router
If you connect the laptop wired, does it work correctly?
If your Wireless router has password protection, try resetting it to factory defaults, and connect it that way. If you can connect with the factory defaults (with no security), it's likely an issue with the security on your router.
I'd suggest starting again. Reset to factory defaults, re-secure the network and try a different SSID name this time, and try again.
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and
hold the reset button for exactly seven seconds. The router lights will
flash and this will restore the router to factory default.
Connect your computer to one of the routers lan ports with an
etherent cable. Open your web browser and navigate to 192.168.2.1.
This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Security-enabled wireless network
go to the wired computer and type in 192.168.0.1 and see if it brings up a box that says username and password. Some routers have different passwords set so go to this link and choose your router from here.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
after you have gotten what your password should be on your router from there then just log in and see if there is an option under security to fix your problem.
