If the engine is running normally and the drive belt between the engine and the transmission is in good shape, most likely you have a failed hydrostatic transmission.
Just experienced the same thing after buying and installing new drive belt it still just sits and makes a clanging noise, go figure. drive belt =Just experienced the same thing after buying and installing new drive belt it still just sits and makes a clanging noise, go figure. drive belt =
You can't post conmments that contain an email address.
Try the friction wheel, you guys over think things. Use a snapper wheel, then use your original friction band, you'll have to modify the snapper wheel a bit but it will fix your problem
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades.
if this dose not help please contact me.
Thank you
