20 Most Recent
Yard Man Yardman Riding Lawn Mower 38in Deck 12 12 Hp Questions & Answers
Have replaced lower drive belt on yard man 604G but now it won't move?
Lisa,
Wow! changing that belt is a chore. It's really hard to analize what's going on but are you sure you replaced all the idler springs? Cuz that can cause a loose belt where you won't be able to move.
Just a thought..was a MTD Rep for 27 years retired 15 years ago.
Here's their contact info... you can very likely get them to send via email a belt diagram to insure it's on correctly or communicate your'e issue and they will help you.
https://www.mtdproducts.com/en_US/contact/
Best to you!
Blades wont engage
check the blade belt if it is ok check the drive belt and tension springs
To remove rear tires on a yardman lawn mower
they have a nut under a cap in the middle of the rim and some have a cotter pin remove the pin take the nut off be sure tire is off the ground trhe pull on the wheel you may have to use a rubber mallet for help to remove it.
