20 Most Recent Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Questions & Answers
if you can provide the model number (usually under the seat), I might be able to pull up a diagram.
Craftsman 20 hp... | Answered on Oct 02, 2018
Make sure belt is installed like drawing.
Craftsman 20 hp... | Answered on Dec 09, 2017
Hopefully this is like your mower Item 56 is your belt maybe it will be of some help.
Craftsman 20 hp... | Answered on Oct 29, 2017
Coil is probably overheating
Craftsman 20 hp... | Answered on Oct 13, 2017
Have you checked the oil in the crankcase, is it full ?
Has engine been sitting along time ?
Have you double checked all the battery conections, all are tight, good ground connection to motor ?
Please let me know.
Craftsman 20 hp... | Answered on Oct 08, 2017
is it a twin cylinder? check to see if it blew one of the spark plugs out. look and see if there is any oil around the engine that looks fresh. it may have a broken connecting rod.
Craftsman 20 hp... | Answered on Aug 23, 2017
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Craftsman 20 hp... | Answered on Aug 09, 2017
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Craftsman 20 hp... | Answered on Jun 10, 2017
Maybe the wire to the seat switch came off or broke, or the switch came loose from vibration. Have you checked?
Craftsman 20 hp... | Answered on Apr 22, 2017
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Craftsman 20 hp... | Answered on Mar 13, 2017
sounds like the drive belts are worn to the point of slipping. need to replace them
Craftsman 20 hp... | Answered on Feb 05, 2017
check your front tire air pressures
Craftsman 20 hp... | Answered on May 22, 2016
Briggs & Stratton engines typically take 48 ounces of SAE 30 oil.
Kohler engines typically take 64 ounces (2 quarts) of 10w30 oil.
Always refer to the dipstick to ensure proper amount is added and do not over fill.
Craftsman 20 hp... | Answered on Apr 25, 2016
Turn key to run. Put screw driver to battery cable side while holding the plastic end of screw driver touch other end of screw driver to cable that goes to starter on solenoid and wjth full charge of battery you should have starter turning.
Craftsman 20 hp... | Answered on Apr 17, 2016
Here is a link to the owners manual which has the belt routing diagram.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0606052.pdf
Craftsman 20 hp... | Answered on Apr 08, 2016
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
Craftsman 20 hp... | Answered on Mar 26, 2016
go to www.searspartsdirect.com and you can look up the diagram on their website.
Also you can download a free owners manual at www.managemyhome.com.
Craftsman 20 hp... | Answered on Nov 14, 2015
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
862 questions posted
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
much oil engine oil change
  • Garden
