When trying to start up our 32" thin LCD TruTech, monitor blinks blue for a couple of seconds, the screen goes black, no sound either.
Not getting sound from trutech 19 in plv16190 what's up with that., can you help me with that
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Very likely have blown fuses and capacitors in both the power supply and the backlight inverter sections. Repair is best left to a technician unless you are tech savy and able to use a soldering iron.
Sombody put a passcode in my tv and locked out all of my channels what can I do to reset it to factory settings thanks. Mike
trutech plv16190. won't turn on, turn on power and turns from red to on for a second then right back to red light. The screen stays black.
IT HAS LINE GOING UP AND DOWN IT AND IT LOOK LIKE IT GOT CRACKS INSIDE OF IT
