20 Most Recent TruTech PLV16320 Television Questions & Answers
2answers
Trutech service number
The numbers for Tru Tech customer service are: 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
10/28/2021 4:04:43 PM • TruTech PLV16320... • Answered on Oct 28, 2021
I need install a RCA ANTENA IN A TTRUTECH TV
Here's the manual, antenna connections are on page 9. TruTech PLV16320 User Manual Connections I have no idea what you mean by "RCA" antenna.
8/8/2016 2:02:30 AM • TruTech PLV16320... • Answered on Aug 08, 2016
2answers
Need code to program direct tv for truetech tv
here is a list of all of the direct tv codes. I do not see your TV on the list, which is sometimes the case. Maybe you will find it there. Hope so.
http://2getdtv.com/directv/tv_codes.html
1/25/2015 3:03:44 PM • TruTech PLV16320... • Answered on Jan 25, 2015
How can i put my trutech 15 in tv on aux with no remote? please help!!
Without its remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier. http://electrohelponline.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Check this link too. http://remotesearch.blogspot.com/
5/6/2014 4:50:35 PM • TruTech PLV16320... • Answered on May 06, 2014
Is this TV set dw19tt analog or is it also setup for didgital
It is both analogue and digital. Refer its user manual for details. Gopakumar Gopalan Google
3/16/2014 6:45:37 AM • TruTech PLV16320... • Answered on Mar 16, 2014
2answers
Need new cable for trutech
I just saw those cables in ebay. good luck! I am looking for the 2nd monitor, mine is not working.
2/26/2014 6:22:49 PM • TruTech PLV16320... • Answered on Feb 26, 2014
Aa password problem
check the manual if you have it because the tv probably came with a factory password for rating movies
2/10/2014 12:49:34 AM • TruTech PLV16320... • Answered on Feb 10, 2014
0answers
How to remove a capacitor
hi you have to desolder it, but if you haven't used a soldering iron before, you could cause a lot of damage i'd look for tech in your area good luck regards shaun
1/26/2014 8:12:50 AM • TruTech PLV16320... • Answered on Jan 26, 2014
I need a remote for a tru tech tv dvd tv monitor plv311995
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. For more information; check the links given below, and find which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability. To get more details, http://electronicshelponline.blogspot.com/
11/20/2013 1:37:38 PM • TruTech PLV16320... • Answered on Nov 20, 2013
Programar el control sky a trutech
buenas noches tengo un tv marca trutech modelo plv1615t de 15 pulgadas y deseo saber que otra marca es compatible para poder programar el codigo gracias
4/17/2013 2:44:30 AM • TruTech PLV16320... • Answered on Apr 17, 2013
2answers
Television Went Dead
When you first turn it on dose the LED blink? if it dose then maybe the inverter board went bad if the LED don't blink then maybe power supply
3/10/2013 3:20:55 AM • TruTech PLV16320... • Answered on Mar 10, 2013
Old tv does not tune to channel 3 or 4
duplicate question.
11/11/2012 1:10:20 PM • TruTech PLV16320... • Answered on Nov 11, 2012
How can i hook my plasma tv up to my computer
simply used VGA cable..
10/17/2012 4:26:50 PM • TruTech PLV16320... • Answered on Oct 17, 2012
When i turn my tv on it automatically sets volume to 30 how do i rest so it does not do this also my speaker does not work on one side and balance is centered
You have a problem in the sound processor/amplifier. Might need attention of a qualified service technician.
7/4/2012 5:13:36 AM • TruTech PLV16320... • Answered on Jul 04, 2012
TruTech PLV16320 Television Logo
212 questions posted
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TruTech Televison & Video
Most Popular Question
put trutech 15 in tv aux no remote
  • Televison & Video
