This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
