Dell P703w Printer Logo
Posted on Aug 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Says I need to replace ink cartridge and won't let me scan or copy anything until I do..is there anyway to bypass that so I can still scan until I get new ink?
Anonymous
Level 3:
  • Master 3,153 Answers
  • Posted on Aug 21, 2010
Anonymous
Master
Level 3:
Answers
3153
Questions
Helped
1166345
Points
11010
Short answer is NO I am afraid
  • Anonymous Dec 16, 2011
    The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    It's removal from puplic view is requested
    Reason. account termination.
2answers
Trying to scan but says low ink and wont scan
You can go to printer preferences and change the setting to print Fast and Grayscale. That should allow you to scan and print if needed until the ink cartridges are replaced.
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Bypassing cartridge message s405
You won't be able to bypass the "missing cartridge" error. All cartridges needs sufficient ink left for the printer to print. If one the cartridges is out of ink it will damange the printhead.
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
2helpful
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
2helpful
2answers
Can I scan
go to scanners and cameras in the control panel and double click on your scanner, you should now be able to use your scanner directly without using Kodiak's software.
Is there anyway I can scan with no ink Epson photo RX620
I'm not certain that I can help, but I am familiar with the Epson does things with their printers and all-in-ones. The thing is, printers are pretty cheap to buy. Where these companies make lotsa bucks is in the aftermarket products, which in this case is printer ink. Therefore, these printers are designed to now allow you to do much of anything with all the ink cartridges installed. I can certainly understand your frustration, and if I am wrong about this, I would like someone who considers themselves an "expert" to tell me so. Good luck, and my advice would be, next time don't buy an Epson. They are the worst company for high-priced ink, and if you use anything except Epson brand ink, you void the warranty. Sucks!
8helpful
2answers
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
