Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Posted on Jan 06, 2018
Epson Stylus TX110, I can print fine but scan has blackish line
I have a Epson Stylus TX110, I can print fine but when I scan/copy a document a blackish line is printed down the left-hand side (the line is about 15mm wide & runs down the length of page). I have tried cleaning the glass with no change also the lid is fully closed so no outside light is getting in.
5 Related Answers
Anonymous
  • 353 Answers
  • Posted on Mar 01, 2009
SOURCE: Epson Stylus C67 keeps printing blank pages
The symptoms infer that the problem is with the computer (printing from an application) rather than the printer (prints OK when the computer is not involved). The best way out of this is to uninstall the printer (start-control panel-uninstall software-epson software). But before you do this double-click the printer icon in the printer list (start-control panel-printers & faxes) and cancel all print jobs in the list (if there are any). Then uninstall the printer Then reboot the computer. Make sure your printer is connected to the computer BUT TURNED OFF. Then insert your printer installation CD and re-install the printer. Turn on the printer when prompted. All should then be well.
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Mar 15, 2009
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 28, 2010
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Anonymous
  • 83 Answers
  • Posted on Mar 16, 2010
SOURCE: loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Anonymous
  • 493 Answers
  • Posted on Mar 27, 2010
SOURCE: black stripe on scanned documents
The HP Scanjet IIP scanners are supported in Windows XP and the drivers included on windows XP CD.
If you can’t manage download it from Windows XP operating system please try to update your Operating system then try again.
All the best.
1. Try going to the bottom of any word document.
2. Click on the language tab (will show current language, eg. "German").
3. Select the desired language (eg. "English (U.K.)"). The select the "Default" button (to make it the default language for every future document).
You can also check this link to get detailed information.
Make sure the document lies perfectly straight on the document table.
If you're printing on glossy paper, prints may be scratched if not handled properly. Don't place objects on top of your prints, and be careful not to scratch them with your fingernails. For best results, frame your prints under glass.
A moiré is a cross-hatch pattern that may appear in a scanned image of a printed document. It is caused by interference from the differing pitches in the scanner's screen and the halftone screen in your original.
  • Select the Descreening Filter check box in EPSON Scan's Home or Professional Mode window. In Professional Mode, set the Screen Ruling of the Descreening Filter setting to an appropriate setting for your document and deselect the Unsharp Mask Filter setting. See Adjusting the Color and Other Image Settings for instructions.
  • Select a lower Resolution setting. See Selecting the Scan Resolution for instructions.
You can also check this link (manual) to get detailed information.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Epson cx8400 stylus will not print from pc.it will copy and scan.dont know what happened
if you have the cd-rom
remove the program,reboot pc.
install the program back and wait whit connecting the cables,
untill the program ask for it.
Epson stylus tx110
Looks to me like the print heads need cleaning. Access the maintenance menu and look for the option to clean the print heads.
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
I am using epson stylus tx110 and i tried to scan and copy a document but there is always appear a black on the the side of a paper when it scanned and printed, how can i remove or set it on full image?...
when you are scanning do set the flat bed cover as flat as you can,?? because when you scan a document with the lid slightly open black lines or shadows might appear. also check the settings of your printer.
5helpful
I have a epson TX110 printer. the printer is skiping lines and bluring lines on the pages printed
You need to go into the *properties icon on the print page and click on maintenance. Once you are in maintenance, click on clean print head and follow the directions. You may need to do it a few times to get it cleaned up if it has gone this far.
* go into a document and click on print as you would if you want to print it. when you are in the first print page, depending on your computer somewhere in the print box will be the properties icon.
3answers
Unable to scan from Epson TX110 but can print
Having exactly the same problem with an Epson SX515W. Did you solve it?
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? [email protected]
My All-in-One Printer
I need to download a driver for my printer epson stylus cx3810
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
