The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the
Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two
SR44's or
LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single
CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
