20 Most Recent Olympus Evolt E510 Digital Camera Questions & Answers
Check if in settings you have something like: lokalizacja (location) or jezyk (language) and change from "polski" to english "angielski"
Changing the display language
You can change the language used for the on-screen display and error messages from
ENGLISH to another language.
MENU
Use ac to select the language you want to use.
• You can add another language to your camera with the provided OLYMPUS Master software.
For details, refer to Help in OLYMPUS Master software. g “Using the OLYMPUS Master
software”
Olympus Evolt... | Answered on Nov 04, 2019
Shooting, with a lens pointing to the sun is always risky for the camera. It could damage the sensor. But with a ND filter, perhaps this could. Then when you are shooting in automatic and just jpg, the camera will try to set the white balance, so the sun comes out bright white. It was the brightest spot in the frame. If you shot RAW you could be better off, because the camera did not change anything to the white balance in rte RAW picture. At least you would be able to restore the colour in a photo editor program like Lightroom or Photoshop RAW.
In extreem light conditions, never use the camera in auto. Only when the camera offers scene mode for that condition, you could use that.
Olympus Evolt... | Answered on Feb 01, 2014
That's because you are using auto focus. That system needs light to actually focus. When it's lacking enough light it uses the build in flash to create enough contrast to focus the objective.
Solutions :
- change to manual focus (mf)
- mount a external flash: then a different method to focus is used
- use a small pocket lamp (the light it produces fades away in the flash)
Olympus Evolt... | Answered on Nov 11, 2011
The first answer is from some one who obviously is not familiar with Olympus (and many other brands of DSLRs) or he would know that many lenses do not have manual focus scales to use. Olympus Standard Grade lenses do not include a focusing distance scale.
The more important issues for you are determining -
1) Are you trying to use "Live View" to focus?
If so you are using a less sensitive auto focus mode. One of the benefits of using a DSLR is that it can use more sensitive auto-focus systems than Point
Olympus Evolt... | Answered on Sep 10, 2010
For Olympus Digital Camera repairs, if your camera is still in the one year warranty contact Olympus directly, otherwise, here is a good reliable repair company https://www.teleplancamerarepair.com/Olympus_EVOLT_E-510
repair will include a cleaning.
Olympus Evolt... | Answered on Jul 16, 2010
CAMARAS USES MORE TEMP FILE FOR THEIR IMAGE FOR BETTER PIC.
U CAN FORMAT THE DISK USING CARD READER.
Olympus Evolt... | Answered on Aug 08, 2009
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $139.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Olympus Evolt... | Answered on Apr 15, 2009
click save as and change location and name
Olympus Evolt... | Answered on Apr 07, 2009
does not record sound on this camera
reset the camera back to factory default using the menu. Put camera is p mode, menu, custom reset, custom reset, ok, yes,ok
After contacting Olympus in hamburg, the problem was solved and installation of the new software (version 2.06) was possible.
There is - however - a bug when you choose the automatic update system. Don not do that and the program is running OK!
The advises from Olympus - Hamburg:
1. Download MSXML.msi from http://www.microsoft.com/downloads/details.aspx?familyid=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&displaylang=en.
2. Run msxml.msi and choose Remove to uininstall msxml4.
3. Run msxml.msi a second time and install msxml4.
restart your PC and install the program
succes
abcmo
Olympus Evolt... | Answered on Apr 01, 2009
hi
better try these go select photos go to properties than uncheck " readonly" than try it it works
Olympus Evolt... | Answered on Nov 21, 2008
What camera?
Is it a pocket camera where the lens in internal? that would explain some of it.
Go into your menu and look up ISO and make sure its not set to anything above 400 if you are worried about digital grain or noise.
for the sharpest image you should have it set to the lowest speed setting.
hope that helps,
Caleb
http://reviews.photographyreview.com/blog/olympus-e-510-pro-review/
try this site.
Olympus Evolt E510 Digital Camera Logo
Popular Tags
22 questions posted
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
EVOLT Olympus
  • EVOLT Olympus
Most Popular Question
blank lcd screen everything else seems
  • Cameras
