After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
