Asko WL6511W Front Load Washer Logo
Posted on Jun 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace drum bearing ... in a ASKO W6551 step by step
Replacing bearing i a ASKO washing machine W6551 ( drum bearing) as it in making a noise all the time....
Anonymous
Level 2:
Sergeant:
  • Expert 351 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
351
Questions
Helped
167406
Points
619
You need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
My washing machine has started making a terrible noise.
If your washing machine has started making a terrible noise, there could be several reasons for this. Here are some troubleshooting steps you can take to identify and resolve the issue:
  1. Check for objects in the drum: Sometimes, objects such as coins, buttons, or zippers can get caught in the drum and cause a noise. Turn off the machine and check the drum for any foreign objects. If you find any, remove them carefully.
  2. Balance the load: If the machine is making a loud banging noise, it may be due to an unbalanced load. Open the machine and redistribute the clothes evenly.
  3. Check the drum bearings: The drum bearings are responsible for allowing the drum to rotate smoothly. If they are worn or damaged, they can cause a loud grinding or scraping noise. To check the bearings, rotate the drum by hand. If it feels stiff or makes a grinding noise, the bearings may need to be replaced.
  4. Inspect the drive belt: If the drive belt is loose or damaged, it can cause a squeaking or rattling noise. Turn off the machine and check the belt for signs of wear or damage. If the belt needs to be replaced, consult your user manual for instructions.
  5. Contact a professional: If you are unsure of what is causing the noise or if none of the above solutions work, it may be necessary to contact a professional technician. They can diagnose the issue and recommend the appropriate course of action.
Note: Before attempting any maintenance or repair work on your washing machine, be sure to unplug it from the power source and read the user manual thoroughly. Also, follow any safety precautions recommended by the manufacturer.
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
2helpful
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
6helpful
Noisy bearing
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • 2helpful
    2answers
    Washing machine has started to make noise. What could be the issue.
    could be coupler or bearings on the bottom of the agitator and tub
    Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
    Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
    2answers
    Bearing noise
    rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
    Top Asko Washing Machines Experts
    ZJ Limited
    ZJ Limited
    NOEL
    NOEL
    Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
