If you can, set the Screen resolution to the maximum native resolution your monitor
supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will
automatically display at the proper aspect ratio, and the monitor will not have
to stretch anything. Setting your screen resolution to match your monitor's
native resolution is, by far, the preferred solution to get you the best looking
display.
If that specific resolution is not available, then you'll need to try
resolutions that are smaller than that, but ideally with the same aspect ratio.
1512x945, for example, would maintain the same aspect ratio. Not all monitors
handle running at less than their optimal resolution well, and it may result in
a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
