20 Most Recent
Acer AL1916 A (Black, Silver) 19 inch LCD Monitor Questions & Answers
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between
width and height of (in your case) your monitor. Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
ViewSonic vg2230 back light keeps going off.
the inverter has gone out. You need to get a new one, but it might be cheaper to buy a new monitor than have it replaced.
If you are able to do it yourself look for it on ebay.
11/12/2017 9:58:16 PM •
Acer AL...
Answered
on Nov 12, 2017
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
4/25/2014 1:41:55 AM •
Acer AL...
Answered
on Apr 25, 2014
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
