20 Most Recent
Dell E193FP 19" Flat Panel LCD Monitor Questions & Answers
I recently bought a used Dell E193FP flat panel
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
How to remove the front bezel from a dell e193fpp monitor by hand?
Seek a troubleshooting manual
http://r.search.yahoo.com/_ylt=A86.JyZM1D9XbXgAZOBEDN04;_ylu=X3oDMTByN2lydWw3BHNlYwNzcgRwb3MDOARjb2xvA2dxMQR2dGlkAw--/RV=2/RE=1463829708/RO=10/RU=http%3a%2f%2fservicerepairmanuals.net%2fcomputer-monitor%2fdell-e193fpc-lcd-monitor-service-manual%2f/RK=0/RS=CK8mHx7DCNfOWVMhlLjDV6MvmXw-
Dell e193fp
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Dell e193FPc monitor
The backlight or inverter may be bad. With the monitor on and the room dark, hold a flashlight very close and shine it on the screen . If you can see the normal display the monitor is OK but the backlight or the inverter which provides proper voltage to the backlight has gone bad.
Monitor goes black. switch flickers green to amber
It does the same with another PC? Otherwise thi model is known to have transistors go out in the inverter circuits here:
http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Replacement board: http://www.lcdrepair.us
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
My new Dell flat screen
You'll need to troubleshoot a little.
SOmething may be broken, but you'll need to find out what.
1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one.
2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken.
3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop.
If the PC will boot with another graphics card, the old one is broken.
4: If not, it may be your motherboard that's broken. Repeat step 3 with it.
These steps should fix your problem. If not, please post back here.
Regards,
Yannick.
LOCK SYMBOL AND KEEPS GOING OFF AND ON
See instructions
here for locking/unlocking monitor controls.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
I have a 5 year
have u tried different pc on the same monitor or may be this monitor on vga out of notebook
Vista video driver needed for Dell E193FP
There are no drivers for difrent monitors.
But if you provide your pcs brand, name, model.
I might be able to find a videocard driver witch might fix your problem.
Oh and what videomode are you trying to use?
Just rebuilt new pc
Dont connect the monitor via your graphic card, its not installed yet. Connect your minitor via the motherboard.
Good luck to you
White screen
one of three items..
video card or driver is kaput...try driver first from dell support site
then, could be monitor..open menu..do the degauss
if not those..then mother board is eternally unhappy
Remove stand
we need picture of it, if your not talking about the swivel base.
LCD Monitor went black
Yes this can be fixed there are a ton of sites out there that have replacement inverters or backlights. A site I found called digitaltechinc.com has parts that can be helpful for this problem. Only if you are willing to patiently do it yourself! It really is not that hard! Hope this helps!
