20 Most Recent Acer AL1715 17" LCD Monitor Questions & Answers
My acer flat screen monitor
I will assume that you have checked out the power cables and external cables. If this is the case you will usually notice an indicator light from your monitor. Universally it is yellow or orange when it has power, then turns green when it detects input from your computer. If the Led light doesn't turn green even when your laptop is already booted, your culprits would be your iMac's video controller or your monitor's input cables.
1/29/2018 9:41:15 AM • Acer AL1715 17"... • Answered on Jan 29, 2018
3answers
(strange) volume control icon stuck in the middle of my LCD monitor and the buttons on the front of the monitor are frozen and will not work?????
Restart the computer. Right click on the task manager > Task manager > End all the programs in Applications folder.
All the best.
Santo
9/18/2015 3:53:00 PM • Acer AL1715 17"... • Answered on Sep 18, 2015
2answers
Monitor goes blank less than a second after turning on.
there is an hardware issue in your lcd it needs to change one of the capaciter please take it to a lcd technician
thanks
1/21/2015 6:09:13 AM • Acer AL1715 17"... • Answered on Jan 21, 2015
2answers
Acer AL1716 power
http://www.go-gddq.com/upload/2009_08/09081816054725.pdf
Let me know if this helps you..
Please take time to vote a thumbs-up :)
12/1/2014 4:54:17 AM • Acer AL1715 17"... • Answered on Dec 01, 2014
3answers
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
10/15/2014 4:08:20 AM • Acer AL1715 17"... • Answered on Oct 15, 2014
2answers
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job. e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
10/15/2014 3:53:50 AM • Acer AL1715 17"... • Answered on Oct 15, 2014
2answers
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
10/15/2014 2:59:44 AM • Acer AL1715 17"... • Answered on Oct 15, 2014
2answers
After i open my monitor then after few seconds its
. Please explain what you mean, after i open my monitor then after few seconds its turn black.model hp1702
5/29/2014 4:55:21 AM • Acer AL1715 17"... • Answered on May 29, 2014
2answers
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
4/16/2014 9:43:21 PM • Acer AL1715 17"... • Answered on Apr 16, 2014
Windows 7 driver
The driver is included in the Windows OS. You should probably look for the video card driver for your computer.
12/10/2013 9:40:25 PM • Acer AL1715 17"... • Answered on Dec 10, 2013
Vertical lines in the monitor
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
8/10/2013 7:20:24 PM • Acer AL1715 17"... • Answered on Aug 10, 2013
How can i fix the shadows on my acer monitor?
The fix is too easy to believe, but it works. I thas happened top me. I was told to separate the wires that come from the back of the monitor. If they are too close together or touching, you get "shadow" or "ghosting". Hope that helps. It fixed mine.
8/31/2012 6:33:10 PM • Acer AL1715 17"... • Answered on Aug 31, 2012
Acer travelmate 5510 and the screen needs to be
Press Fn key next to CTRL key and use the left and right arrows to make screen dimmer and brighter whole still holding the Fn key down. :)
8/6/2012 9:45:49 AM • Acer AL1715 17"... • Answered on Aug 06, 2012
How do I lighten my laptop screen--Compaq
Go under the settings area and pic visual it should be there
5/15/2012 3:22:35 PM • Acer AL1715 17"... • Answered on May 15, 2012
When the computer is on
I know this has been said before but , check the caps. on yhe power supply .
7/12/2011 8:56:06 PM • Acer AL1715 17"... • Answered on Jul 12, 2011
Acer AL1715 17" LCD Monitor Logo
151 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
remove acer monitor
  • Computers & Internet
