The damper is usally installed with a damper installation set these are long all theaded studs with nuts and washers andyou screw in the right threaded stud and then install the damper then thewashers and then the nut tightening the nut to pull the damper on. It's very inportant to line up the key exatly as if oof just some it won't go on. I've all ways been able to clean everything with blaster line up the key carefully and tap it on with a light hammer just far enought to start the bolt then keep tapping as you tighten the bolt to help not stripping the thraeds as it's still staring as only t few threads are pulling after its halfway in you can turn it with an impac but tapping with the hammer may still help. heating the damper is riskly to do as the rubber insulation may get too hot and fail the rubber. You can dress the crank nose with a file but you need to do it carefully and evenly scraches made by sandpaper or poorly guilded file can make the shaft bigger as in sven tighter too get the damper on blaster and a rag rubbing both parts is safeest
