Dell A215 Computer Speakers Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I connect speakers wire 9 pin plug to 9 pin plug on sound card - both are male ends
Anonymous
Level 3:
  • Master 4,102 Answers
  • Posted on Jan 25, 2010
Anonymous
Master
Level 3:
Answers
4102
Questions
26
Helped
1200622
Points
14563
Hi, all you need to do is go to a computer hardware store and just ask them if you can buy a male to female converter these can be brought for next to nothing and this will then solve your problem.
Let me know how you get on or if you need further assistance ok
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
2answers
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Hi, I have a Shuttle SK21G (admittedly not a current product). It uses an external sound card because I thought this would be of better quality than the on-board sound chip. The only drawback is that I...
> which is fiddle when changing between speakers and headphones
Purchase a 4-foot "extension" cable -- plug its MALE end into the AUDIO-OUT from the sound-card.
Bring the FEMALE end of the cable to somewhere in front of your computer.
Bring the MALE ends of BOTH the speakers and the headphone to the same location.
Then, when it's time to "fiddle", then the plugging/unplugging is right there, in front of you, and will be much easier to do!
Cost: about $5.
I have a fisher price smart cycle and do not see how the wires fit onto the TV . the wires are yellow, white , red but i don't see how they fit am i missing something or some part that makes it fit?
Generally speaking, the yellow wire is for the video (the pictures and graphics on the screen), and the white and red wires are for the audio (the music and sounds for the speakers). The white wire would be for the left channel or speaker, and the red wire for the right channel or speaker. The connections for these wires are usually RCA phono plugs. These plugs have a small metal cylinder or jack in the center of the plug, and 3 squarish metal pieces surrounding the jack - the whole jack or plug looks a bit like a flower with its stamen in the middle.
These RCA jacks fit into corresponding holes or sockets on your TV that are color-coded just like the plugs are - there should be a yellow socket for the video, and a red and a white socket for the audio left and right. Most TV's have these sockets. On older TV's, there should be a yellow, red, and white set of sockets on the front or the back of the TV that the jacks from the wires you are trying to connect fit into. On newer TV's, like high-definition TV's, these sockets might also be found on the side panel of the TV.
You can check your owner's manual for your TV to see what sort of connectors/sockets it has available. Usually most TV's will have a set of RCA connectors to plug your wires into. Other types of connections include VGA, DVI, or HDMI. If you do not have any RCA connections on your TV (unlikely), then you can cheaply buy an appropriate adapter from your local electronics store or a place like Radio Shack or Wal-Mart.
Some of these adapters are called "Y-adapters," and allow you to connect all 3 of the yellow, red, and white wires, to the adapter, and then the adapter plugs into the appropriate connector on the TV, which might be a VGA connector, or even an HDMI connector. Again, check the owner's manual for your TV, and bring it with you if you need to go hunting for an adapter to connect your device.
For your reference, VGA connectors, the older type, are usually blue in color and have 9 pins for the male connector, or 9 holes, for the socket. Whether it's audio, video, electrical wiring, plumbing, or computers, the "gender" of a connection is always the same: the socket or holes end is female, the male or pins end is male.
The newer HDMI connectors are flat and have just one row of pins or holes inside a metal sheath.
So, basically, you need to figure out what sort of connections your TV has to plug into. If it has red, white, and yellow RCA phono connections, you are all set. I do hope that this has not confused you further! I do try to help, and I wish you all the best in connecting your smart cycle.
Westinghouse model LCM 17V2SL what type of wire is needed to get speakers to work?
You need stereo mini phone plug male-to-male, one end goes into audio line out (green) on the PC sound card, the other end goes into audio line in on the monitor jack (green). then you need to set the volume control PC and at the monitor. You can get the cable from Radio Shack.
2helpful
Need to replace the 9 pin male plug that goes into the woofer box,so need pinout diagram
All I wanted was a pinout diagram for the male plug so that I could wire up a new plug. Did not want to have to re-mortgage the house to get that. Thought such info would be free.
Anyway have stripped away all the plastic moulding to reveal the connections so am OK now Thanks
Jim Goldsmith
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
2helpful
2answers
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
5helpful
Spherex IR cable replacement
After looking for this cable and talking to some of my friends - I was able to determine what type of cable it is. it is called a Mini din 9 pin male to male.
Molded Cable, Mini din 9 Pin Male to Male, 6.0 feetI bought from this guy - http://www.stockcable.com/products.php?pid=17&detail=true#thumb
hopefully you fellas from across the pond can find a place to purchase it.
X-230 Xbox 360/Computer Problem.
Frist Things first!
1) CHange the input cables for Spks, for another with cooper or gold conductivity.
2) clean ends for dust on inputs.
3) try to reconnect the speakers carefully and test sound.
you can figure out when some sound are bad in any connection on this way.
Good Luck
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
