20 Most Recent
Logitech X-230 Computer Speakers Questions & Answers
No sound at all, but power on. Should I replace the phone jack?
Hi Hermann ,
This is a typical issue with Logitech speakers . You need to bring them back to the the dealer and get an exchange set for free replacement onder warranty . If the warranty has expired , you will need to solve the problem by testing the cables or the printcircuit inside the sub , BUT first connect your head phones or another speakers set to the correct output of your computer's soundcard to verify if the issue actually commes from the speakers . If the test is negative , the issue is to be found in the soundcard and you will need to replace it .
Best regards .
Broken green pin on logitech x230 can this be replaced
if the green pin is what plugs into your computer, a traditional, headphone 1/8th inch headphone jack, it can be replaced, however there is some soldering involved. Radio shack sells the replaceable ends for just a couple dollars. the only problem is knowing which wires to connect to which points on the new end. i would have to see the wire with the insulation stripped off to be able to tell you which are which
